EAR-POINTING (oreilles d'elfe) - Questions générales
Re: Ear-pointing (oreilles d'elfe)
Messagepar Dollink_ » Mer 16 Avr 2014 19:29
Hiiii, réponse !!
thank you for contacting us.
Ear pointing procedure costs 1800 Euros and we would need to see good close up picture of both of your ears before we can agree to do it on you as not every ear type is suitable for that procedure.
Samppa's technique is way different from the classic "folding" one and basically he reshapes the whole cartilage and he uses internal permanent internal sutures to support the new shape of the whole ear as well like outside and front side external sutures. Time of the healing is around 14days so the sutures are taken out and swelling normally is gone however the final shape it takes up to few months the same like with the subdermal implants, you can see the shape but of the proper and final shape you need to wait a bit longer so they look better and better over time.
Procedure is done in sterile environment and under local numbing and can take between 2-4 hours per ear. Healing time is not very painful, I would say that is a bit sore but normally you can back to work.
As a aftercare it is recommended to take antibiotic for at least few days because after the procedure the blood circulation in your ear area is very weak so the risk o infection is very high that's why we recommend to take them for few days. On top of it arnica pills and just keep it clean.
I will need to know if you have any problems with blood circulation, any allergies as well as trouble with healing.
Please let me know if you have any more questions.
We will be in Paris in September.
Regards
Aneta Von Cyborg
Bweuuuh 1800 euroooos :'( j'pourrais jamais réunir ça avant septemmbre ><
Donc ouais je pensais pas que c'était une procédure aussi délicate, surtout juste après pendant la cica
Donc ce passage c'est flou pour moi si quelqu'un peu m'expliquer "so the sutures are taken out and swelling normally is gone " les fils se résorbent d'eux même ? Pardon si ma question est abrutie mais je m'y connais vraiment pas :s
Et deux à quatre heures :shock: si c'est souffrance tout le long, ça doit être dur à gérer
Tattoos, Labret, Indus, Septum, Tetons, Labret Vertical, Medusa, Narine Pointed ears / tongue split
Dollink_
Messagepar Profil supprimé » Mer 16 Avr 2014 19:38
c'est sous anesthésie locale si j'ai bien suivi comment il procédait :)
Messagepar caCtus » Mer 16 Avr 2014 19:39
"the sutures are taken out", je comprends que les points sont retirés, pas spécialement qu'ils partent d'eux-mêmes.
Pour la suite il dit qu'après 14 jours le gonflement s'est résorbé mais que les oreilles n'auront pas tout de suite la forme finale, ça prend quelques mois.
Et oui ça semble parler d'anesthésie locale. :pink:
caCtus
Messagepar Dollink_ » Mer 16 Avr 2014 19:41
caCtus a écrit:"the sutures are taken out", je comprends que les points sont retirés, pas spécialement qu'ils partent d'eux-mêmes.
c'est bien ce qui m'inquiétait, mais du coup qui peux le faire s'il reste pas 15 jours?
Miel chuis une bille en anglais, j'ai loupé ça :p
Dollink_
Messagepar Profil supprimé » Mer 16 Avr 2014 19:43
t'inquiète :)
Pour les sutures, une infirmière te le fera si tu vas à l'hopital il me semble. (ou même une infirmière à domicile, on m'avait retiré les sutures sur mon pied directement chez moi -> mais j'avais une ordonnance pour qu'on me le fasse à domicile)
Messagepar caCtus » Mer 16 Avr 2014 19:43
Pose peut-être la question a des bodmodeurs français qui accueillent des guests, est-ce que dans ces cas-la ce sont eux qui se chargent de retirer les points/faire un suivi?
Ou alors tu vas chez un doc et tu le mets devant le fait accompli! :D
Modifié en dernier par caCtus le Mer 16 Avr 2014 20:10, modifié 1 fois.
caCtus
Messagepar Dollink_ » Mer 16 Avr 2014 19:45
Mdr ouais c'est ça qui m'emmerde un peu, mais bon, si y'avait que ça j'passerais au dessus lol
Dollink_
Messagepar hanatori » Mer 16 Avr 2014 19:55
Perso quand Urd m'avait retiré un bout d'oreille, c'est ma pierceuse à Albi qui m'avait retiré les points ^^ Mais je pense en effet que le mieux c'est de voir avec l'hôte du guest si tu es à côté
┌∩┐(◣_◢)┌∩┐
hanatori
Messagepar Dollink_ » Mer 16 Avr 2014 20:00
Jsuis assez loin de Paris donc bon :/ l'option infirmière serait la meilleure, ça sera toujours moins cher je pense. Bon je lui demande combien de temps il sera sur Paris et combien de temps à l'avance il faut "réserver", si j'ai le temps de voir, car financièrement si niveau taf ça roule y'a moyen mais ça, jle saurais que fin mai ^_^
Dollink_
Messagepar Funambule » Mer 16 Avr 2014 20:57
Funambule
Messagepar Dollink_ » Mer 16 Avr 2014 21:04
Aaah, merci ! :D j'ai galéré à chercher j'sais pas comment j'me suis démmerdée ^^
ça fait super "naturel" aussi
Dollink_
Messagepar Krän » Mer 16 Avr 2014 21:42
Depuis 2010, je ne sais pas s'il a changé sa procédure...(?) mais le tarif a pris +800€ (1000->1800). Aïe un petit peu quand même... :p
Messagepar Dollink_ » Mer 16 Avr 2014 21:50
800 euros par oreille? Oui, cher, c'est sûr, mais c'est assez long quand même
Dollink_
Messagepar Profil supprimé » Mer 16 Avr 2014 22:01
si j'ai bien compris Krän, en fait c'est 1800€pour les 2 oreilles.
donc l'augmentation n'est pas si importante, c'est de l'ordre de 150$ de + par oreille me semble
Messagepar Daria » Mer 16 Avr 2014 22:16
c'est intéressant comme post!
autant certaines mod m'inspirent pas trop, autant ça je trouve ça "joli"
il est bien le mail sur la procédure; mais là comme ça ce qui m'interpelle, c'est comment tu chopes les antibios qu'ils recommandent? c'est sur ordonnance normalement donc faut demander à ton médecin avant? :scratch:
Daria
Messagepar Krän » Jeu 17 Avr 2014 14:59
Miel a écrit:si j'ai bien compris Krän, en fait c'est 1800€pour les 2 oreilles.
(1000€ -> 1800€) 800€ de plus pour la procédure, donc si on veut décomposer ça fait 400€ de plus/oreille. :D
Mon interrogation porte plus sur : "A t-il changé sa procédure ? (Ce qui pourrait expliqué le prix quasi doublé entre 2010 et aujourd'hui.)"
Messagepar Profil supprimé » Jeu 17 Avr 2014 15:12
'(j'avais cru comprendre que c'était 1000$ par oreille avant -> donc 2000$ (environ 1500€ ) les deux )
Messagepar Krän » Jeu 17 Avr 2014 15:17
La grille tarifaire que j'avais eu c'était noté : "1000€ £1000 132000yen", pas de pris en USD ou AUD.
'fin bon, plus que le prix, je chercherai l'info sur la procédure nouvelle ou pas. :)
Messagepar MrBrightside » Jeu 17 Avr 2014 20:42
Punaise, me parents vont me réclamer une sacré somme...
Sont pas belles oreilles d'elfe 100% naturelles :D
Croquer la fouf.
En cours-Manchette florale, Flo Amblard
Aventure scar.
MrBrightside
Remercié: 17 fois
Messagepar Dollink_ » Sam 19 Avr 2014 09:40
qui m'ennuie c'est que je devrai dire adieu à mon indus... Mais bon, j'ai trop envie de ses oreiiilles ><
Modifié en dernier par Dollink_ le Mar 10 Juin 2014 11:35, modifié 1 fois.
Dollink_
