EYE TATTOO - Informations, possibilités, ...
Re: Eye tattoo - informations, possibilités, ...
Messagepar CottonCrow » Sam 21 Déc 2013 16:46
Connaissez vous des pro se déplacent en france en Guest par exemple, qui le pratiqueraient ? j'y reflechis depuis quelques temps ...
CottonCrow
Messagepar mutantxtatique » Sam 21 Déc 2013 19:30
pour une telle procédure un voyage ne serait-ce qu'à Londres peut être une bonne solution ;)
Messagepar Elvia » Sam 21 Déc 2013 21:38
impressionnant :shock:
... As you were ...
Elvia
Messagepar CottonCrow » Dim 22 Déc 2013 13:22
mutantxtatique a écrit:pour une telle procédure un voyage ne serait-ce qu'à Londres peut être une bonne solution ;)
Londres, tu incinue Sampa ? Ou qui d'autres ?
CottonCrow
Messagepar mutantxtatique » Dim 22 Déc 2013 16:00
Roni Lachowicz
Messagepar Krän » Dim 22 Déc 2013 16:41
D'ailleurs j'aime beaucoup l'intro de la section de son site :
Tattooing eyeballs is a procedure where the sclera of the eye is coloured by a series of ink injections. As can be seen by the pictures below, this has a dramatic effect on appearance of the recipient. Black often tends to be the colour of choice but a range of colours can be used.
Obviously this procedure is full of risks and should never, under any circumstances, be performed by someone who has not received proper instruction. It is also a procedure that should not be taken lightly as currently there is no known way to reverse the placement of coloured pigment inside the eye.
In addition to this, there is currently no study of the long-term effects of having your eyeballs tattooed.
If you are considering this procedure, please take time to seriously reflect on how this will change your life, how your friends, family and loved ones will react to your changed appearance and most of all, future employment complications.
Do not consider this very extreme modification until you have fully contemplated its effects at great length.
Messagepar blutsalat » Lun 23 Déc 2013 14:53
CottonCrow a écrit:Pour revenir au sujet, le eyeball tatoo, Connaissez vous des pro se déplacent en france en Guest par exemple, qui le pratiqueraient ? j'y reflechis depuis quelques temps ...
Pour ceux & celles qui seraient décidé·e·s et voudraient chopper une fenêtre pour en profiter, le pionnier de cette technique fera manifestement un rapide saut dans l'hexagone tout début janvier 2014, cf ce fil dans la rubrique pros en vadrouille. Inconvéniant : ce n'est que dans quelques jours et au vu de la période de l'année mouvementée, il faut très vite se manifester si réellement motivé·e.
blutsalat
HeavyModeur
Messagepar blutsalat » Ven 27 Déc 2013 21:04
Il arrive effectivement à produire des nuanciers et effets de texture assez saisissants :
blutsalat
HeavyModeur
Messagepar Coin-coin le Canapin » Dim 29 Déc 2013 09:51
Par contre les couleurs sont pas vraiment statiques, elles bougent et se mêlent pas mal avec le temps. Plus que dans de la peau :geek:
Messagepar Shinigamylle » Mar 31 Déc 2013 08:38
Le eyeball tattoo est vraiment une pratique saisissante, les rendus sont vraiment géniaux, même quand l'encre migre sous la peau en effet "œil au beurre noir" (je trouve que ça donne un effet "trop dark" sympa).
Le blanc de l'oeil en noir donne un rendu hypnotisant, j'adore franchement, plus que les autres couleurs (le gris est pas mal d'ailleurs, l'effet est intéressant !)
Je m'imagine avec le blanc de l'oeil noir, j'ai les yeux bleus avec le centre de l'iris vert/jaune avec la lumière, ça pèterait grave ! :lol: Mais… Ça restera fantasmatique pour moi, je tiens beaucoup trop à mes yeux pour expérimenter, même si le rendu est terrible.
En tout cas, merci aux traducteurs, franchement quelle patience, je n'aurais jamais eu le courage de lire les articles non traduits !
Modifié en dernier par Shinigamylle le Ven 31 Jan 2014 12:34, modifié 2 fois.
Messagepar Krän » Mer 1 Jan 2014 14:56
Comme expliqué dans le premier post, ce n'est pas la cornée qui est tatouée afin d'obtenir ce type de rendu.
Messagepar Shinigamylle » Jeu 2 Jan 2014 23:48
Krän a écrit:Comme expliqué dans le premier post, ce n'est pas la cornée qui est tatouée afin d'obtenir ce type de rendu.
Ah désolée, faute éditée, merci ! ^^
Viola a écrit:
blutsalat a écrit:Il arrive effectivement à produire des nuanciers et effets de texture assez saisissants :
wowowowow :eek:
J'avoue ne pas être très fan des eyeball tattoo en couleurs (sauf pour faire ressortir un iris très sombre) et que je préfère le noir et le gris. Mais tous les résultats restent super agréables à regarder, et tout aussi fascinants !
La modification corporelle est vraiment un monde fabuleux :love:
Messagepar skjæra » Dim 26 Jan 2014 16:19
Je rejoins Shinigamylle, tout en noir c'est... Particulièrement fascinant et attirant :love:
Et puis, changer le regard, c'est vraiment "puissant" je trouve!
Mais la technique va tout doucement commencer à décoller dans les milieux plus ''populaires" si je puis dire, à en croire l'article (en anglais) ici: http://noisey.vice.com/en_se/blog/eww-j ... ll-tattoos
En gros, un jeune musicien (artiste dancehall) jamaïcain a décidé de se faire encrer les yeux pour suivre son idole (lui même dans le milieu), pour attirer l'attention... Idole qui pense que ça s'en ira après quelques temps. Le jeune lui, a été "admis à l'hôpital après que l'aiguille ait percée trop profondément".
skjæra
Messagepar Krän » Jeu 30 Jan 2014 21:30
Typiquement le genre de m*rde qui traine sur le net...
Cette photo stupide tourne depuis bien longtemps...
Des glands ("AFTER TATTOOING HIS OWN EYEBALLS") qui font du buzz, et des ""articles"" avec des commentaires complètement cons "adult people without brains", "which sounds like a really sadomasochistic way" ...
Je pense que même la presse standard ignore ce genre de contenu... Et heureusement.
Messagepar desperados61 » Jeu 30 Jan 2014 21:32
:eek: Ils sont malades!
Mon univers sombre
WIP : jambe bio-orga par Éric de l'Etoile
desperados61
Messagepar Krän » Jeu 30 Jan 2014 21:41
Non mais c'est une connerie cette photo hein, un fake, un hoax, ... (On voit bien qu'il n'y a pas d'aiguille/porte aiguille :roll: ) -_-'
Messagepar desperados61 » Jeu 30 Jan 2014 21:43
:geek: (merci de me rassurer :arrow: part se cacher, j'ai honte...)
Mon univers sombre
desperados61
Messagepar el padrino » Jeu 30 Jan 2014 21:46
:shock: :roll: dafuck.
non mais ya vraiment des gens...
el padrino
Messagepar Shinigamylle » Jeu 30 Jan 2014 22:11
Déjà, j'enlèverais ma casquette !
Pff, t'façon, le net, y'a tellement de choses/gens bêtes qui traînent...
Messagepar Néya » Jeu 30 Jan 2014 23:17
Pas fan, d'autant que les porteurs de lentilles peuvent oublier ce type de bodmod je pense...
Néya
